tee pulling
MikeyB
Member Posts: 696
Beautiful work Rob, very nice
Like pulling teeth (Tee)
For anyone who has considered using a tee puller, this is for you. This fabrication is of a 6"x3" pull on L copper. I roll groved both the 6 and the 3 for ease of working with on the job site. I never checked the price of a 6x3 tee but I'm fairly sure its spendy. This was certainly a much quicker and cheaper alternative.
Robert O'Connor/NJ0 -
Fab Shop?
Do you have a fab shop or is this a one time pull? We used t-drills 20 years ago nd they were great for ptting tees wherever needed.
It would be interesting to do a comparison in order to see what is more cost effective. I am guessing the tee is about $400.00. You must have spent several hours with setup etc.
Great work I have never worked with that large of a T-Drill. Did you have to pre-heat the pipe prior to the pull?0 -
fabby
Fab shop yes, one time pull no. There were 3 to do and start to finish it took apox. 3 hours to finish all 3. I preheat anything over 2&1/2". I think it could of been done sooner but the tool didn't want to cut out the material were marked, thus not allowing the head to enter the pipe. I had to finish the holes with the pencil grinder. Another problem was the groover which decided to "walk" 2 times thus making some pretty expensive "rabbit's". After making a few boo boo's, the last one only took 20 minutes.
Thanks for the comments!
Robert O'Connor/NJ0
