New boiler fill, how long to boil to clear oxygen?
one person's advice was to bring the water temperature up to 190 deg and leave it; but in your case you will probably want to skim the boiler, and that should be more than enough heating to drive out the oxygen.--nbc
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    I just had a Smith Model 19-6 re-piped, so it's been drained and refilled. Since heating season is pretty much over, how long should I fire the boiler to clear out the oxygen that is in the water to reduce the corrosion from the new water.
    Thanks,
    Steve
    Steve from Denver, CO
    Jamie Hall Member Posts: 26,838
    Nick's right --
    bring it up to a good full boil and the oxygen in the water will be pretty well gone.
  • Steve Garson_2
    Thanks!
  • the real question is
    Why was the boiler repiped? Do you have before and after pictures?
