pex fittings in walls
Paul Formisano
Paul Formisano Member Posts: 25
should you use pex fittings in walls? with ss crimp rings?
  • kpc_73
    kpc_73 Member Posts: 26
    do it all...
    time time w/ copper rings.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Nothing is better than this is a wall or floor
    Not one failure-ever
  • I have had leaks
    I use to use the crimps on my water treatment equipment before the neutralizer and found that acid water very quickly ...within a year ate the outer edge of the barb on the fitting and leaked. This happened several times. I have never used it after the water was treated.
  • Supply House Rick
    Everloc is not a crimp
    Not even close
