pex fittings in walls
Paul Formisano
should you use pex fittings in walls? with ss crimp rings?
do it all...
time time w/ copper rings.0 -
Nothing is better than this is a wall or floor
Not one failure-ever0 -
I have had leaks
I use to use the crimps on my water treatment equipment before the neutralizer and found that acid water very quickly ...within a year ate the outer edge of the barb on the fitting and leaked. This happened several times. I have never used it after the water was treated.0 -
Everloc is not a crimp
Not even close0
- 133 Chimneys & Flues
