Insufficient Hot Water
Wilsonk
Member Posts: 1
I have an oil powered boiler with a bock indirect hot water heater. It was installed Dec 2005. It was providing plenty of hot water than all of a sudden it is not. The only thing that occurred was I had my annual maintenance done and a leaking pressure relief valve on the boiler system replaced. The oil guy did say it sounded like I had some air trapped in the system that was knocking and he couldn't get it all out. At this point we did not notice a hot water problem, it wasn't until a week or two later. It is only noticeable when there is a significant demand. I have turned up the temperature on the hot water tank. It has made the water hotter so it does last a bit longer but I still don't have the same supply I used to enjoy. The recovery also is really slow. What do you think I am dealing with?
check & inspect
WHAT you are dealing with is you need a qualified mechanic to check & inspect your system. could be just a minor adjustment was overlooked or incorrectly set. not all servicemen are equal.0 -
water temps
Those coils generally don't get air-bound. They are top fed. Wouldn't hurt to check hivent if it has one, but he could have easily lowered the limits on the main aquastat on the boiler. This will cause a recovery problem. Could have been an honest mistake, but if they can't solve it, perhaps they are lacking knowledge in other areas as well. peace0 -
Do you have hard water? You may have a problem with scale on the domestic side of the coil insulating and cutting the heat transfer rate.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
