freezer badly in need of cleaning
JSPAK
Member Posts: 25
ok here it is bottom line. stand up doubledoor freezer control went bad . school was shut down for week ... i am heating tech but got called in because school stunk and stuff ooozing out of doubledoor commercial freezer .... hmmmmm .. i got there and digital tstat said 113 degrees .food was cooked smelled geeeez.my theory is the defrost was stuck. overheated freezer for however long . all food was evacuated .... they cleaned compartment with bleach . lock doors and removed outside... make long story short .what procedure to get rid of smell before i start troubleshooting
rif odor
two ways stand back open doors go in with hose and simple green and follow up with baking soda cleaning and air out or go in FDS you get that the drug store0 -
Try vanilla in a bowl.0 -
I've used
coffee and balled up newspaper very successfully in a residential fridge/freezer. Slow but effective. Also used to use coffee in reefer trailers to get rid of meat smells.
Just my 2c0 -
Time
Unfortunately, the best way to remove teh smell is to leave the doors open and wait.
If you jump out the door switch and allow the system to operate, the evaporator fan will help circulate air through the coil and eventually out of the box.
Placing baking soda in the box will work, but a dish with lemon juice will help as well.
Please keep us posted.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
