mod con gravity conversion
Dave_132
Member Posts: 65
I just completed a gravity conversion to forced circulation in a 90 year old home. Installed a Lochinvar Knight with primary/secondary piping, a squire indirect water heater and all pumps with internal flow checks. I also installed strainers on the return piping in order to stop any foreign matter from hitting the new pumps and I installed a strainer on the inlet to the boiler. The passage ways are so small that junk from the old piping could damage the boiler as well.
I've been asked to give a bid to replace a coal converted water boiler to a mod con. Any tips for piping i presume a primary secondary. The radiators are all large cast iron (gravity setup). Thanks Robby0 -
strainers for sure
Robby which ever mod con you use i would recommend a strainer and also use a low head pump other wise you may end up with alot of over heating due too to muh flow (b&g 100)You could also ease up your primary seondary piping by using a hydro seperator califee and b&g have some nice ones and for the extra ost it makes piping a bit quiker and easier with alot less pipe distances to take into account for peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 167 Indoor-Air Quality
