mod con gravity conversion
I just completed a gravity conversion to forced circulation in a 90 year old home. Installed a Lochinvar Knight with primary/secondary piping, a squire indirect water heater and all pumps with internal flow checks. I also installed strainers on the return piping in order to stop any foreign matter from hitting the new pumps and I installed a strainer on the inlet to the boiler. The passage ways are so small that junk from the old piping could damage the boiler as well.
  • Robby
    Robby Posts: 5
    I've been asked to give a bid to replace a coal converted water boiler to a mod con. Any tips for piping i presume a primary secondary. The radiators are all large cast iron (gravity setup). Thanks Robby
  • clammy
    clammy Posts: 3,260
    strainers for sure
    Robby which ever mod con you use i would recommend a strainer and also use a low head pump other wise you may end up with alot of over heating due too to muh flow (b&g 100)You could also ease up your primary seondary piping by using a hydro seperator califee and b&g have some nice ones and for the extra ost it makes piping a bit quiker and easier with alot less pipe distances to take into account for peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
