Are there any plastic vent system listed to UL1738?
Hello,
I think my subject says it all, are there any plastic flue gas venting systems the are listed to UL1738?
I can't seem to find any...please help.
Thanks,
Ivan
  • joel_19
    joel_19 Posts: 933
    What are you trying to vent how and why?
  • bob young
    bob young Posts: 2,177
    the solution
    COMPLY with manufacturers spec & building dept. regulations.
  • Henry
    Henry Posts: 998
    Plastic venting
    There are a few manufacturers that are now certified to ULC636. It is basicaly PVC or CPVC with a new colour and certification labeling of standard sch 40 pipe! They even use the same pressure/temperature ratings of pressure pipe!
    It is a marketing ploy as ABS has less expansion and a higher temperature rating before deformation. But ABS gives off more noxious gases when applying the EXTERNAL flame test of the standard. There is no INTERNAL temperature testing for the ULC636 standard.
  • tim smith
    tim smith Posts: 2,935
    Check this link out to IPEX vent piping. Approved as you said
    http://www.ipexinc.com/Content/en_ca/2_0_Products/2_4_Plumbing_Mechanical/2_4_9_System636.asp
