Are there any plastic vent system listed to UL1738?
Ivan_2
Hello,
I think my subject says it all, are there any plastic flue gas venting systems the are listed to UL1738?
I can't seem to find any...please help.
Thanks,
Ivan
Thanks,
Ivan
What are you trying to vent how and why?0 -
the solution
COMPLY with manufacturers spec & building dept. regulations.0 -
Plastic venting
There are a few manufacturers that are now certified to ULC636. It is basicaly PVC or CPVC with a new colour and certification labeling of standard sch 40 pipe! They even use the same pressure/temperature ratings of pressure pipe!
It is a marketing ploy as ABS has less expansion and a higher temperature rating before deformation. But ABS gives off more noxious gases when applying the EXTERNAL flame test of the standard. There is no INTERNAL temperature testing for the ULC636 standard.
Check this link out to IPEX vent piping. Approved as you said
http://www.ipexinc.com/Content/en_ca/2_0_Products/2_4_Plumbing_Mechanical/2_4_9_System636.asp0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
