Looking for Kewanee Boiler Info
bert
bert Member Posts: 50
I have some info on hand. What is the nameplate info?
  • Rich L.
    Rich L. Member Posts: 414
    Re-tube job
    I have a customer that wants a price on completely re-tubing an older Kewanee boiler. I'm having trouble finding information about what tube material to use with Kewanee out of business. I have all of the info off of the plates. Any info is greatly appreciated.
    Thanks, Rich L
  • Rusty Powers
    Rusty Powers Member Posts: 30
    Re-tube
    Check with Burnham, I heard a rumor that they bought Kewanee...
  • Rich L.
    Burnham's busy
    Wow, on hold for over half an hour. I can't get through to them.
  • boilerpro_4
    boilerpro_4 Member Posts: 12
    Burnham is closed today!!
  • bob_46
    bob_46 Member Posts: 813
    Tube
    probably .095 wall carbon steel. Do you have an R stamp ? a lot of states require an ASME R stamp to retube a boiler.
  • Rich L.
    Explains that!
  • Rich L.
    Name Plate
    This is all the information I have off of the name plate on the jacket and under the cover right above that there's another plate directly on the boiler shell itself.
    Manufacturer - Kewanee Boiler
    Year built - 12/73
    Model - 7L287 ("H" Stamp)
    Serial # P-0526
    WAS7l285KG0
    Date 3-28-73
    53462IA
    Max steam 15 psi
    Max water 30 psi
    I429HS
    VCII432LB
    I973
    9800
    Thanks for all the responses and any help. Rich L
  • Rich L.
    Another Quote
    my customer received called for 3" OD x 12 guage SA178A tubes. My boss won't let me run with that, what if they were wrong? Once we re-tube it we own it, if anything were to go wrong anyway.
    Standard "Carbon Steel" won't cut it either. We've got to use the same materials spec'd by the manufacturer, even though they're not around any more. If I'm wrong on this please feel free to correct me. You'd save me a lot of work! But tell me where I can find the documents to back it up.
    Yes, our shop has an "R" stamp.
    Thanks again for the help.
  • bert
    follow up
    84 direct tubes, 3" od, .105 wall, 10' - 3-3/4"
    60 return tubes, 3" od, .105 wall. 12' - 2"
    note .105 wall is prox. 12 ga, field verify lenghts
    lengths shown include 1/2 to 1" for beading or flaring
    use min. A106 or better
    American Tube & Iron will have tubing in stock
  • Rich L.
    Thanks Bert!
