The better 80% furnaces
Are you talking gas or oil?
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Have a customer that needs a new 80% eff. furnace replacement, locally Ruud are Available. what is the opinion on them ? Thanks Richard
  • Derheatmeister
    Nat Gas
  • Darin Cook_9
    Darin Cook_9 Member Posts: 45
    Why 80%?
    For the minimal price difference I would sell them a 90% or higher. Is this a seasonal residence/camp where they do not want to worry about the condensate freezing up on the furnace?
    Darin
  • tim smith
    tim smith Member Posts: 2,886
    Look at 95% energy star, they qualify for 30% tax credit up
    to 1500.00 and also the local utility might have a rebate program. This very likely would offset difference or close to it. Tim
  • Wayne_16
    Wayne_16 Member Posts: 130
    Ruud, Rheem, Weatherking
    Have all been a good furnace for a long time. I feel a quality product, with stainless steel primary and secondary heat exchangers. It has been some time since I worked with a company that sold the Rheem/Ruud brand, so I am not up on the latest inprovements. Like all equipment, proper installation is the key. Personally I liked using the bottom return, for the return air. More even loading of the blower assembly, resulted in less warranty or air flow issues.
    Minnesota Wayne
  • Derheatmeister
    Cannot Condense
    Thank's, Yes the furnace cannot be a Condenser! Venting and other restricting Issues apply or are restrictive enough to not Qualify the 90 + eff. Otherwise i would naturally offer and 90+ eff.!
  • John Mills_4
    John Mills_4 Member Posts: 43
    Go for it
    Ruud makes a great furnace. If he wants the best, the 2 stage variable speed unit is a nice one. Match with Vision Pro IAQ and will properly stage plus can offer dehumidify on demand for extra summer comfort.
    Have not had 1 failure of a Rheem/Ruud furnace tubular heat exchanger since they came out in 1992. No ignitor means less problems for the customer.
