Replace LWCO ?
James_30
James_30 Member Posts: 1
I have a MM series 67 LWCO 15Years old and the float & switch have to be replaced. Question should I replace the whole unit, body and all, or just clean out the old body and replace just the float switch unit.What do you pros normally do. Thanks James
  • Tough question,
    MM recommends replacement every 10 years, myself I have stretched that.
    The housing is CI, so if it appears clean(little scraping), and the cost of the replacement float & switch still seems attractive to you, then I would risk-it.
    Assuming its low pressure of course.
    Dave
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    After 15 years put it to rest
    "M/M recommends replacement every 10 years" it's called Liability. Do you want to be responsible if something goes wrong, not me, been to court twice in 20 years and won both times because I did the right thing. Didn't even tell insurance company until after the fact because I didn't want them to settle because it would be cheaper for them, but not me. For the difference in price I would replace it.
  • tim smith
    tim smith Member Posts: 2,886
    Lose it, the cost of MM parts will not be that far off replacing
    it. Plus it is a safety device that is quite critical.. Tim
  • bob young
    bob young Member Posts: 2,177
    go brand new
    i have had at least one defective replacement switch. why take a chance. go electronic if possible
