Thermostatic boiler bypass?
JohnNY
Member Posts: 3,231
What do you think?
(see pic)
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=290&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
(see pic)
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
John
Wouldn`t you want the return temp to close the valve?
Dave0 -
John
I think Dave is correct.
The sensor should be on the return below the cross over.0 -
Yes.
I agree.
Thanks.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
If its a German boiler...
the first location would werk.
But if its an American boiler, what the other guys said...
METhere was an error rendering this rich post.
John
Ever tried those ESBE thermostatic valves available through Danfoss?
They may be a better price, and it has no probe.
Dave0 -
OK Dave & John
You got me. Just bought a big CI for construction heat and snow melt for a MacMansion. The dealer needed the cash flow and it was almost free. The "REAL" heat will be radiant powered by solar then mod/cons.
That valve and set up would make my life easier and save a ton of plumbing.
Thanks0 -
Got a new client with a c.i. boiler suffering from condensation.
You might've guessed I'm trying to create an inexpensive and effective bypass that I can fit on some lower-cost installations and retrofits.
Unfortunately, I just got a price on the valve I wanted to use for this.
and it's gonna cost me $450/per unit.
Vaffanculo for $450.
So, it's back to the proverbial drawing board for me.
Classes0 -
It would, Dave, thank you.
I had considered using that very unit but was trying to avoid using a three-way valve.
I see I may have to.
Classes0 -
John, there was a valve that Weil Mclain used with thermostatic
control in it for boiler protection. I think it was on the HE or VHE boilers. I think it was made by Taco??? cast body. Tim0 -
We use White-Roger's motorised valves of 1/2 the diameter of the return line, in the bypass line. We control it with a snap disc set for 130F on the return to the boiler. It is cheap, works well and so far 9 years, not one snap disc or motorised valve has been replaced!0 -
What's that?
A little 24volt zone-type valve wired right to the transformer switched by the snap disc aquastat?
Classes0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
