Measuring Electric usage, small meters, Etc?
Do they make a small meter that you plug an appliance into to measure electric usage?
Rob
  • Kill-A-Watt
    Is a small plug in wattmeter that also measures voltage, current, KWH, elapsed time, frequency and power factor. I have two of them and they work great.
    I bought mine on Ebay new for about $25 including shipping. Amazon also sells them.
  • T.E.D
    This is on my wish list
    The Energy Detective
  • Uni R_2
    Uni R_2 Posts: 589
    WattsUp
    https://www.wattsupmeters.com/secure/products.php
    The pro and better versions will interface and log data on your PC for you.
  • Rob Blair
    Rob Blair Posts: 227
    But does it do cumulative. If I left it plugged in for a month would it total all the watts used for a month?
  • Yes
    It measures consumption cumulatively in KWH for as long as it is plugged in, and power is not interrupted. For example, a 100W light bulb plugged in for 10 hours will register 1.00 KWH at the end of the period.
