dirveway snowmelt question
Timco
Member Posts: 3,040
Should a driveway that is being melted actually steam, or is that just too many btu's in those loops?
Thanks, Tim
Thanks, Tim
Just a guy running some pipes.
That's OK Tim...
You have to get the driveway warm enough to melt the snow, and if it is cool enough outside, it is normal to see evaporation. Kinda hard to control a slab temp and keep at right at 33 degrees F :-)
I believe it's called vapor pressure...
ME0 -
Steam is good. Never had a complaint on a steaming snowmelt. That means it's working well.
Rod0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
