dirveway snowmelt question
Timco
Timco Posts: 3,040
Should a driveway that is being melted actually steam, or is that just too many btu's in those loops?
Thanks, Tim
  • Mark Eatherton
    Mark Eatherton Posts: 5,876
    That's OK Tim...
    You have to get the driveway warm enough to melt the snow, and if it is cool enough outside, it is normal to see evaporation. Kinda hard to control a slab temp and keep at right at 33 degrees F :-)
    I believe it's called vapor pressure...
    ME
  • Steam is good. Never had a complaint on a steaming snowmelt. That means it's working well. :)
    Rod
