Problems with Chinese drywall and copper products
D107
D107 Member Posts: 1,944
Are copper pipes labeled so you can tell origin?
http://www.cnn.com/2009/US/03/18/chinese.drywall/index.html
  • sounds like a witch hunt
    and while i can't prove it, bec i don't have cu fittings from way back, i think the dry-fit tolerance has become less precise by whomever-made
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Tolerances
    Have become unacceptable, except for 1 1/2 - 2" up sizes IMHO...and I have some old fittings from the 70s-80s to prove it...same goes for the thickness of L, M copper, and Romex wire.
