Compression tank mystery
Servicewiz_3
Why would a compression tank (non- bladder type) have a compressed air line running to the top of it???? Any help is greatly appreciated!!!!
What's the line connected to ?
If there's a valve at the top of the tank , my guess is to let air in when draining ?0 -
compressed air line ?
take a pic and post it?0 -
because...
it kept waterlogging (are there vents elsewhere in the system?) and the HO figured it was easier to add air w/ a compressor than to drain water and allow air to enter naturally?0 -
air line
Is it a B&G fitting or equivelent? Some exspansion tanks of old had these fittings to direct air to the top of the tank for ease af draining when they got full. They must also be sealed back up during operation, or the tank would fill right back up, or there is a pin hole in the tank allowing it to fill in less than a year. Thread sealer on the bleeder. peace0 -
I service a 10 story condo bldg and could not get the tank to hold air so I made a ftg that screws onto the hose bib drain and plugs into my compressor. System runs very different with half a tank of air! It was flooded all the time before, and I was called because they had the relief valve on one of the two boilers changed 4 times and were tired of being charged for this. Has not popped once since I got air in the tank and there was no other way to get air in there besides the compressor...
TimJust a guy running some pipes.0 -
Vents
Scrook's nailed it. I've seen this many times on large commercial systems. The operating engineers (I think stationary engineers is a better name) do this because it is an easier solution than correcting the underlying problem. I have also seen this practice cause some expensive problems.
P.S. Using a compressor to add air to a tank is not a problem, leaving it connected can be.There was an error rendering this rich post.
- 133 Chimneys & Flues
- 172 Indoor-Air Quality
