hey tim smith
rather than lose this potential solution in the original 'challenge' post; maybe i'm missing something, but if you're saying that removing the nips is a problem, i may have a solution
and, i seem to recall burnham selling replacement nips
  • tim smith
    tim smith Posts: 2,935
    I do not think the nips are correct size for old american Rococo
    rads. If you have a good solution for removal, lets hear it...
  • guessing that the problem
    is rust/age etc, and the typical removal problem/solution with any threaded joint, penetrating oil/torch heat; do the oil, but take your nip wrench and attach it to an impact wrench. i adapt my rigid r6300 for everything, and sometimes operating it in both directions, loosening and tightening, for very tough threads. on the most recent toughie, i forget right now what it was, but after oil and torch, i had to loosen/tighten 8 times before it finally broke loose and unthreaded
  • Josh_10
    Josh_10 Posts: 786
    Hey Tim,
    I have a proposal. I think you should change your screen name to King of Queen Anne LOL. It just came to me.
    Seems like I see two of your trucks every time I drive through there.
  • tim smith
    Bow before me Josh!!! :)
    Good to hear from you, Tim
