Duramax in a van or a Sprinter.
Erich_3
Member Posts: 135
The Duramax engine was designed by Isuzu. They are world class producers of reliable diesel engines. They set up a partnership with GM called Dmax to produce the Duramax in Ohio. GM has since bought out Isuzu and is the sole owner of Dmax. It would be hard to find a better light truck diesel than the Duramax. It is not only powerful but quiet.
I am leaning towards the Sprinter
I did see some things go by here about problems with them over the last year. It costs a bit more but you cant ignore the fuel savings and the extra space. I have a 06 F350 with a covered workmaster body. The body is great but the engine has failed twice and I have yet to reach 70K. I have heard that is the way the 6.0 is and the new 6.4 is not any better. No more Fords for me for a while. I have been really happy with our silverado with the Duramax. Its time for another van though. How are the Sprinters doing out their?0 -
Sprinter with 10K
and I have been very pleased. Mileage in the long, tall version low 20's. 10,000 between oil changes. very nice and comfortable cab layout, seats adjust, 12V power plugs, storage nooks abound, and plenty of cup holders.
A bit drifty in big winds is my only complaint, lots of sheetmetal
My neighbor takes care of 30 Sprinters for City Utilities here. They have had excellent results, most ly stop and go driving. 16-19 mpg with them idleling a lot at jobsites. They run 15K between oil changes after years of oil analysis. My Ford 6.0 needs oil changes every 3K, and lots of oil.
Here are some tie downs I found for those rails in the bed. Same rails the airlines use to mount seats, by the way. www.sortimo.com/index.php?id=1&L=1
Here is an interesting Sprinter website, shows the hybrids and some unique applications.
www.whnet.com/4x4/sprinter.html
hrBob "hot rod" Rohr
sprinters
We've got 2 old ones 02's over 100k miles few problems at first to get sorted but they have been problem free the last few years. Much better mileage than duramax van and you can stand up in them. Imperial Chrysler in Mendon Ma is blowing out some left over high roofs right now for around 34k can't beat that price i think0 -
Sounds food
Thats a long haul from northern California though. I did not know about the oil changes being that far apart. I spend alot of money on oil and filters with the trucks we have. Five thousand miles in a month is a easy month
Fat fingers F is next to G you know how it is. have Food day.0 -
Sprinters
I have a 05 long high bay unit. Get 23+ in summer and 20 winter, 86K on the truck currently. Put new front brakes at 70K and new tires at 75K. The only problem Ive had was there was crap on the metal before paint on rear doors and some on right rear panel, found at 40K and the wouldn't cover under warrantty. Looks like boils coming thru the paint. I'm going to work on it when it gets warm.0 -
New Sprinter
Will, Call your local dealer -Autoworld Petaluma. You should be able to get a new Sprinter somewhere between $6-7K below msrp. They have a large dust covered inventory!!
Enda0 -
Going today to look at one. I have seen them for 9K below list.
Rob0 -
9 below
I think it's time get rid of the gas hogs!
Enda0 -
Look at Freightliner Dealer for Sprinter
You might want to check at your local Freightliner dealer. Freightliner is owned by Mercedes and the Sprinter is assembled in the US Freightliner factory. You eliminate the middleman by going direct to Freightliner. Another thing to think about is the possibility that Chrysler may go bankrupt.0 -
they build them in Germany, then
drop the power train out and ship them over. they are re-assembled here. Avoids some sort of tariff or import regulation, according to my dealer.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
