looking for used tankless...
chris_24
Member Posts: 22
heater...
I know it sounds strange, but my customer wants a used tankless. I guess he thinks he will save some money, and maybe he will, so I told him I would ask around.
problem is, no one sells anything used. I need either a Takagi, or a Monitor tankless. Monitor would be my preference, but either way will work.
anyone have any ideas on where to get one???
I have tried, but am out of ideas.
thanks for the help
thanks for the help
did you....
look on ebay, craigslist, classifieds?
Some codes will not allow you to reuse water piping from 1 home to another home let alone a water heater.....kpc0 -
thanks
I have tried ebay, and craigslist.
saw a few on ebay I would have purchased, but he insists on used. why?? the price for new is not that expensive, but its not my decision.
I would just pass on this project, except there isn't much work right now, times are lean, and jobs are hard to come by.0 -
then he'll just have to wait,
bec it took me a while to find a used one, $250 on ebay, and i'm sure you won't have your choice of brand0 -
Try Low Energy Systems in Denver
303-781-9437
Ask for Neil Greene.
METhere was an error rendering this rich post.
used paloma tankless
Well not heavily used. The had problems with altitude (elevation 6500') would cycle a couple of times then quit. It is set up for propane. Use time is very low. I think that are are several extra parts for the unit. Attempts from the rep trying to make the unit function.
It is from a customer I looked at doing work and am waiting to hear back from them on the bid for work. If you are interested let me know. I can get model #.
JoeThere was an error rendering this rich post.
hey mark, thanks for the tip
low energy systems, scratch and dent
http://www.tanklesswaterheaters.com/blemlist.html0 -
What use will it get, one person, two, or home heating, what btu is needed, tankless sell for new 500 - maybe 3000.00. New has warranty and didnt freeze0 -
thanks
for the reply's...
thanks mark, will defenately check out low energy systems.
this will be used for 2 baths, potable, and small section of the house for heating. so the load is not huge, but needs to be able to keep up.
thanks again
chris0 -
Savings
With the cost of labor. Is it worth it? Ask questions like. Why did they take it out? What problems am I going to have? What will it cost me to get it working right? I haven't been pricing them in the US, but what I paying for them in Europe I wouldn't consider a used one.
Mac0 -
Heating and 2 baths,, forget tankless,if you will run two baths at once or a shower and another person uses a sink then in winter all 200,000 btu could be needed for HW. Unless there was a way to automaticly shut down building heat. These are mainly designed for personal HW. What BTU is needed for heating.You wont gain in effecency over a boiler, do you think you will.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
