Modular Boilers
Rich Kontny_3
Member Posts: 561
Can be a nightmare for steam as it is hard to balance the condensate into numerous boilers as needed. We had better luck with two versus one with burner modulating. This gives you some energy advantages plus back up.
Rich
Rich
Steamhead and other steam pros
Any one use the modular approach when replacing large boilers serving an old one pipe steam system?
If so do you have any wisdom to share regarding piping configurations.
I have read Dan's excellent article on modular and now am looking for additional information based on actual installs. ie trials, tribulations, successes
ALL input gratefully accepted!0 -
I've had good luck on modular steam....
with stage firing. I have done 2, one one pipe steam with gravity return and one 2 pipe feeding steam coils with cond pump return. The one pipe steam boilers are staged with a two stage thermostat and an aquastat on the end of the slowest heating main to get both boilers running on an initial call for heat. Slant Fin had been doing modular steam for about 30 years. Larry, at Slant Fin tech services really knows these modulars well. Others here have since used staged boilers and two stage gas valves together on a single installation with success.
Boilerpro
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
More than two?
We did a water utilty filter/pump house with six boilers and they had nothing but problems. You seem to use a lot of copper on your steam systems. Any problems with that?0 -
Only two so far.......
Buildings don't get that big out here in Northwestern Illinois. Copper only gets used on returns or drips. A number of guys here at the Wall with many years in on steam have been using copper in this application for over a decade without issues. It tends to stay cleaner and does not rot out like steel in wet returns.
When using modulars, it is really important to pipe them to spec. Large returns, full size equalizers, and large risers keep the pressure drop between modules at a minimum. Just remember, the famous Mills boiler is a modular boiler, as is any cast iron sectional boiler, for that matter. You just have to equalize each module properly.
Boilerpro
Water Balance NITEMARES
is an understatement!!! I don't know if I want to step into this one! Five VGA400 about 5 years old, serious water line issues. I am convinced the plant is grossly oversized as I have never seen more than 3 units operate at any time. Keeping them running is a trick.
Nice deep drop header pic. Inspectors will not let copper come anywhere near steam on our installs.Return lines only!
Thanks for the feed back guys.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
