A mon, are you into rousta?
Timco
Timco Member Posts: 3,040
I have one rousta bout fitting that is leaking..a 90* elbo ever since I drained a large system. 3" pipe. Do these seal up like the others did or does it need to be changed? Are the 90's the same gasket as the couplings?
Thanks as always, Tim
Just a guy running some pipes.
