compression tanks
Servicewiz_3
Servicewiz_3 Member Posts: 69
What is the reasoning behind pressurizing (with air ) The top of a standard (non-bladder type) Expansion tank ? Any help is greatly appreciated !!!!!!!!!!!!
Servicewiz
  • heatboy_21
    heatboy_21 Member Posts: 2
    Not sure why.......
    ..... anyone would even consider that. The tank makes it's own cushion of air as it's filled. Once the air is in there, and provided the tank is piped to the system correctly, the air will never leave the tank. If there is a waterlogged tank issue, it's because the tank hasn't been piped correctly and the thermal circulation associated with it.
  • Whoever told you that
    was confusing a heating system expansion tank with a well-pump system expansion tank.
    Two different animals.
    Dave
