baseboard flow rate
It will lower the DT yes, and slightly raise the output as the temperature-drop across its length is maintained at a higher level.<BR><BR>Dave
  • STEVEN MARKS
    STEVEN MARKS Member Posts: 154
    baseboard flow rate
    Will too much flow thru baseboard fin tube cut back on the output or just lower the Delta T.
    Steven
  • STEVEN MARKS
    Thank you dave That is what I was thinking.
  • scrook_2
    scrook_2 Member Posts: 610
    look at a baseboard data sheet, they give output per ft for various average temperatures at 1 and 4 GPM -- the latter's just slightly higher than the former for the same temperature.
