baseboard flow rate
It will lower the DT yes, and slightly raise the output as the temperature-drop across its length is maintained at a higher level.<BR><BR>Dave
baseboard flow rate
Will too much flow thru baseboard fin tube cut back on the output or just lower the Delta T.
Steven0 -
Thank you dave That is what I was thinking.0 -
look at a baseboard data sheet, they give output per ft for various average temperatures at 1 and 4 GPM -- the latter's just slightly higher than the former for the same temperature.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
