extrol tanks
billtwocase
Member Posts: 2,384
Paul, you need to meassure the amount of radiation. Any brand of tank will have a size chart, or they should.
extrol tanks
how can you tell what size expansion tank to use on a system? [ extrol #15,#30, or #60]ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Im a Ho so I know didly, but My tank was attic and with new boiler basement. Boiler over pressured until extra was installed. Extra meaning extra.0 -
That must be an old house. Sounds like a 60 is what's needed. It can't hurt to oversize the extrol tank, but undersizing, i'll bet you know the result0 -
So...
probably a gravity (now pumped?) system w/ large cast iron radiators and large iron pipes feeding them, (and formerly an open attic expansion tank) vs. a system w/ finned copper tube baseboards. A system like that holds a lot of water so needs a larger Extrol tank. Higher water temperatures and larger system volumes both lead to larger X-tank requirements. How big's the current tank (number or dia & height)?0
- 167 Indoor-Air Quality
