tankless coil on oil boiler switched to indirect heater,energy s
Robert O'Brien
Robert O'Brien Member Posts: 3,591
unless you setup the boiler to either cold or warm start as applicable.You want to eliminate as much of the idle loss of the boiler as possible,the standby loss of an indirect is much,much less
  • Rich Poline
    Rich Poline Member Posts: 1
    If I switch a tankless coil to an indirect water heater on a 175,000 btu oil fired water heater how much energy can I expect to save in one year?
