New Pressure Reducing Valve Install (Steamhead and Gordo)
E-5 pressure reducing valve finally decided to quit. Since the incoming steam pressure from the local district steam grid was 35 psi and we wanted to run 2-3 psi downstream from the valve, just replacing the E-5 like for like was not the way to go, since the E-5 is designed for low differential pressure drops.
The condensing can on the side is to keep the steam from the valve's rubber diaphragm.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
