burnham alpine
wet head in wi_2
Member Posts: 2
Has anyone installed one yet. pros cons and what ya think of them installing first one next week
I'm interested...
..in how the install goes for you. Keep us posted. Let us know what you think.
Ross0 -
Looked into ...
I looked into using one for a job. Found out it is not made for wall hung application.
Didn't use it.0 -
alpine
Just went throught the factory assembly line and training for it last week..... I think is is a winner and I do believe if installed and piped well to keep the flow and delta T right through the boiler it will be great. I do believe that water quality is an issue . They do have very specific venting instructions which do need to be followed, and the max circulator amps the board can handle is 2 amps which Is the only thing I dont like. But any seasoned boiler guy should be fineMark Overly.0 -
first one for me
In the process of installing my first one cant wait to fire it off. My questions/concerns are how to properly transition from burnham supplied cpvc to sched 40 pvc what type cement works on both as think I will be using a pvc coupling...next question is this house has a once converted qravity system feed and returns are 1.5 inch should I reduce to .75...Other than that I will go strictly by the book and Iam sure it will work JA0
- 167 Indoor-Air Quality
