Solar & huge useage pool, seattle????
Mark Custis
Member Posts: 537
I got an email from RETscreen about a software up date. If you haven't looked at it yet please do so.
I was very disappointed in solar yield as it is currently available. RETscreen helped change my thinking.
I thought that maybe this customer of ours pool would be a perfect fit for solar savings. 60x13 pool, uncovered, 91 degrees. Man does it use gas.. He cannot get his wife to let him put a cover on it and it is ran year around. Can you say large carbon foot print. I thought I would look into solar for it, he is game. Perfect flat roof area facing south to put panels on. Well, I looked into solar panels, albeit not a lot of area to put them. 16ft long area with 6ft long panels or tubes. The way it laid out, the rep ran it on his program and depending on # of tubes, 60 to 80 or 4 flat panels it would produce between 20 million and 30 million btus annually. Sounds impressive put that way. Now boil it down, that is between 200 and 300 therms of gas a year. I was shocked at how little we would get out of it. That is between $260 & $390 yr savings. At somewhere's over 10k to do job depending on tubes or plates it just does not make sense. Also I would not be surprised if there is more carbon produced to make the equipment than what is saved from the install. I just could not justify this. Feedback is appreciated and I am sure there will be some. Thanks, Tim0 -
plastic solar panels
doesn't surprise me in seattle.
what about the simple plastic solar panels for pools?
automated pool cover?
what can you do when the customer refuses the simplest most cost effective way to solve the problem?(pool cover) then just walk away......0 -
Tim,
Stop by my office, I have TSOL and have done allot of pool payback analysis. I'm distracted right now but those numbers don't seem right.
Currently we're doing a 140 tube system and another 7 flat plates for a gigantic pool in Issaquah. Thee payback pencils very well.0 -
I wouldn't trust RETSCREEN. How can you trust them if you can't see their assumptions. After doing BTU monitoring on a few jobs, we found RETSCREEN to be off by 20% in most cases. TSOL on the other hand, has been fairly accurate. I must say though, that is only after one year of monitoring.0 -
Josh. I'm comparing TSOL and RETScreen at the moment. Do you feel RETScren is 20% Higher or Lower?0 -
Josh, I looked on solar panel websites and then had it
ran on tsol. Pretty close to same #s. Tim0 -
I'm guessing Viessmann then? Who ran the sims?0 -
I googled TSOL
and came up with a rock band.
I am sure they can turn up the heat, but.......0 -
Consider...
a LIQUID pool cover. Reduces energy consumption by up to 50%.
http://www.flexiblesolutions.com/
Also, seeings as how you're up where it rarely gets below freezing, consider using an air source heat pump with a titanium HXer to heat the pool.
Running with a COP of 5:1 has to be cheaper per therm than an 80% efficient boiler..
ME0 -
Not really, they sing about neckrophilia.0 -
Thanks Josh
That helps me without having to listen.0 -
40%
Our experience with liquid pool cover is more like 40%. Automatic cover will get 70%. Heat Siphon makes a great air to water heat pump. Has nice website to help size things...0 -
Solar Pool Heating
I think it probably has the quickest payback because you have a year round low temperature load. It is simply a lot easier to make 85 degree water, and at those low temperatures flat panels would be very effective. I have a customer that years ago put in a couple of the cheap unglazed collectors and he was very happy with the performance, he never used his cover after that. There was an article recently on pool heating, I think maybe in Solar Today or PM Magazine. It was in a public school and they had a sucussful install with a short payback. The only problem is I don't think renewable energy tax credits would be applicable.
Thanks, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
