Need Part in NYC
David L. Taylor
oswald??????
Need Part in NYC
Heat Timer Corp. no longer supports HPD Gold Series product.
I need an Outdoor Solid State Temperature Sensor (Weatherhead) P/N 904002.
Anybody know where I can get it?
Thanks
try oswald0 -
This place on Chrystie St in Chinatown stocks all that:
Pronto Gas Heating Supplies
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
oswald
H C Oswald Supply Co , Inc
725 Whittier St, Bronx, NY 10474-6016
Contact Phone: (718) 620-1400
or H & L SUPPLY AVE H & CONEY ISLAND AVE bklyn [ BRIAN ] OR BRUCE SUPPLY BKLYN CROPSEY & 18 AVE OR DAVIS & WARSHAW MASBETH
HPD sensors
We do still support our product if you are correct that it is an HPD control the unit is not repairable as it is over 20 years old.
Also the proper sensors for the control would be a 904220-00 outdoor weatherhead and indoor sensor. This is the new replacement for the two older model sensors. We still have the 904002-00 Blue weatherhead available but that would not be the proper sensor for the HPD control.
Kevin Gabelmann0 -
Kevin, are any 120V timing motors still available for the old EPC controls? I believe the 120V relays are still available. Do you have part numbers for the 120V coil 4PDT timing relay and the output relay?0 -
Heat Timer
Heat Timer Corp. sent a tech and the tech condemed the unit, said it was obsolete & no parts available. I cleaned the insides with tuner cleaner and believed that the problem could be cleared up with a new weatherhead. Instead of having me install a purchased weatherhead, Mgt. sent NY Heating (which replaced the weatherhead) and the system works fine now.
Just a note about Heat Timer - Mgt. has soured on their product, in large part, because it won't support older models. It is replacing, as necc'y, with either Fuel Watchman, or computer systems other than those products offered by Heat Timer Corp. It's a shame because I always liked Heat Timer products; but I'm not the boss.0 -
obsolete equipment
but looking on the other side of the coin they may not want to work on it because they feel uncomfortable extending a warranty on such an outdated product. they may have gotten burnt in the past. i prefer techmor. heatimer was always over rated. they should have discounted a new unit for you. lo not a chance !!0 -
EPC Relay.
Mike,
The relay is part #500005-06. They are in stock. This is the plug in relay. They should all be the same on the front of the panel. The relay hardwired on back is the same also just not field replacable. The timing motors are not available for the EPC unit anymore.
Kevin Gabelmann0
- 133 Chimneys & Flues
