radiant pump?
i have a couple of 300ft loops of 1/2" pex was put in using 10" on -center --would the up--58 pump work? for a 300ft loop ?
  • Mark Custis
    Mark Custis Member Posts: 537
    A few is how many?
    More info needed.
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    i pump for each loop -doing seperate pumps
  • Rod Kotiga
    Rod Kotiga Member Posts: 68
    If each loop is a seperate zone then use two pumps. If the two loops go to the same zone then one pump. Either way a 15-58 will do the job.
  • heatboy_19
    heatboy_19 Member Posts: 1
    What are .....
    .... the flow (GPM) requirements? Knowing that will give you the pressure drop of the loops. Without that, close your eyes and pick a pump.
  • it's pretty hard to think that a up15-58 wouldn't push two loops for any flow rate the loops are capable of handling.
