radiant pump?
oil-2-4-6-gas
Member Posts: 641
i have a couple of 300ft loops of 1/2" pex was put in using 10" on -center --would the up--58 pump work? for a 300ft loop ?
A few is how many?
More info needed.0 -
i pump for each loop -doing seperate pumps0 -
If each loop is a seperate zone then use two pumps. If the two loops go to the same zone then one pump. Either way a 15-58 will do the job.0 -
What are .....
.... the flow (GPM) requirements? Knowing that will give you the pressure drop of the loops. Without that, close your eyes and pick a pump.0 -
it's pretty hard to think that a up15-58 wouldn't push two loops for any flow rate the loops are capable of handling.0
