Custom C. I. Baseboard
AL_35
Member Posts: 4
I am in the west burbs of chicago. I have an account at controlled. Thanks for the info
Cast Iron Radiator Sizes
I looking for a company that makes custom sized cast iron baseboard radiators. I have four radiators sizes 66", 55", 132 3/4" and 138". The origianls froze and broke. I could repipe them and put in standard but would much prefer to get exact replasements. Any help would be appreciated.
AL0 -
depending where
Depending where you are located, get ahold of Control'd Engineering , 630 469 7300, they can make any size radiator you want..0 -
Controlled
No luck at controlled
talk about
Talk about small world! I have some used thin tubes radaitors waiting to be used.0 -
Al do you know the make? Custom length may not matter if you can not get them the same height as you have now.Cost is what you spend , value is what you get.
cell # 413-841-6726
They are two different styles of radiator. I think I am going to order the Weil-Mclain and add the dummy ends. I not to worried about the btu load because they are way oversized anyway.
thanks
AL0
- 167 Indoor-Air Quality
