Custom C. I. Baseboard
AL_35
AL_35 Member Posts: 4
I am in the west burbs of chicago. I have an account at controlled. Thanks for the info
  • AL_35
    Cast Iron Radiator Sizes
    I looking for a company that makes custom sized cast iron baseboard radiators. I have four radiators sizes 66", 55", 132 3/4" and 138". The origianls froze and broke. I could repipe them and put in standard but would much prefer to get exact replasements. Any help would be appreciated.
    AL
  • depending where
    Depending where you are located, get ahold of Control'd Engineering , 630 469 7300, they can make any size radiator you want..
  • AL_35
    Controlled
    No luck at controlled
  • talk about
    Talk about small world! I have some used thin tubes radaitors waiting to be used.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Al do you know the make? Custom length may not matter if you can not get them the same height as you have now.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • AL_35
    They are two different styles of radiator. I think I am going to order the Weil-Mclain and add the dummy ends. I not to worried about the btu load because they are way oversized anyway.
    thanks
    AL
