Bathroom Floor Warming
Brent H.
Brent H. Member Posts: 169
Unfortunately, There is not enough floor area to heat it effectively with purely radiant heat. There are 2 outside walls and a window.
  • Brent H.
    I'm looking for suggestions on a cost effective way to warm the floor of the bathroom in the addition I'm building. There will be a section of baseboard heat to warm the room so I'm just looking to make the tile floor comfortable for bare feet. I'm open to something electric or a system that will use the water being supplied to the baseboard. It's typical wood frame construction with a full basement below. Currently just 3/4" plywood on the floor. Any ideas would be appreciated.
  • Mark Custis
    Mark Custis Member Posts: 537
    We just
    replaced the baseboard and made the floor the heat emitter.
  • Mark Custis
    Do the floor and
    the outside walls as heat emitters. That small of a job they can afford raupanel on 6 " oc.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    I used.....
    this in my bathroom. Works great!
    http://www.warmwire.com/
    Jim
  • troy_8
    troy_8 Member Posts: 109
    Electric
    Electric radiant makes a lot of sense in a space like this. You can enjoy a warm floor even if the rest of the heating system is off. Installation is simple. with a setback stat it will be warm when you enter the bath in the morning and shut down for the rest of the day. If you need info contact me at Lvgheat@verizon.net.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    STEP Warm floor
    http://www.warmfloor.com/
    Self limiting plastic thermal film. Will be using it in my own home soon.
    ME
  • Rick_93
    Rick_93 Member Posts: 2
    I would go with the RAUPANEL
    Best floor system out there! Our entire first floor is raupanel. We are running 115'F and are quite comfortable!
    Sales 101, never underestimate what a customer will pay for comfort. Never assume what they can afford...
    Rick
