Survey of old ornate radiator types please, Tim
Paul Pollets
Paul Pollets Member Posts: 3,671
a Chinese mfg. company...they can copy anything. It's very unlikely any US manufacturer will re-cast the old styles again. The costs of manufacturing and limited demand don't make much business sense. Burnham's the exception, but the Classic radiator(s) are not available in 36" heights.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • tim smith
    tim smith Member Posts: 2,886
    Looking for what you all see to be most prevalent for old
    ornate cast iron column type radiators. We see mostly American Rococo out here, what do you see. Are they the most widely used from the 1920s to 30s. Need this to see if trying to get repros made in quantity would be worth it. Thanks all, Tim I mainly want to see if the Rococco's were the most common in the east coast as they seem to be here in the northwest over other fancy cast rads. Here is the type I am talking about.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    where is out here?
    where are you? how about some pix of your local rads!-nbc
  • Big Ed_4
    Big Ed_4 Member Posts: 3,368
    Burnham
    Burnham makes a nice ornate cast iron radiator. Check their site.
  • tim smith
    The Burnhams are just not close enough of a match,
    I have been looking into this for quite a while but still seeing if I can make sense of it. Thanks, Tim
  • The Rococo
    seems to be the most common around Baltimore. Are you going to do the steam-only or the hot-water pattern?
  • tim smith
    Thanks Steamhead, I would do the water config
    that way could be used on both. Tim
