Survey of old ornate radiator types please, Tim
Paul Pollets
Member Posts: 3,668
a Chinese mfg. company...they can copy anything. It's very unlikely any US manufacturer will re-cast the old styles again. The costs of manufacturing and limited demand don't make much business sense. Burnham's the exception, but the Classic radiator(s) are not available in 36" heights.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Looking for what you all see to be most prevalent for old
ornate cast iron column type radiators. We see mostly American Rococo out here, what do you see. Are they the most widely used from the 1920s to 30s. Need this to see if trying to get repros made in quantity would be worth it. Thanks all, Tim I mainly want to see if the Rococco's were the most common in the east coast as they seem to be here in the northwest over other fancy cast rads. Here is the type I am talking about.0 -
where is out here?
where are you? how about some pix of your local rads!-nbc0 -
Burnham
Burnham makes a nice ornate cast iron radiator. Check their site.There was an error rendering this rich post.
The Burnhams are just not close enough of a match,
I have been looking into this for quite a while but still seeing if I can make sense of it. Thanks, Tim0 -
The Rococo
seems to be the most common around Baltimore. Are you going to do the steam-only or the hot-water pattern?
Thanks Steamhead, I would do the water config
that way could be used on both. Tim0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
