Hydronic heating with rinnai tankless waterheater.
Dan C.
Member Posts: 248
Rinnai is not approved for closed loop heating.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=329&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Hydronic heating with a rinnai tankless
I am looking for any piping diagrams. Do I have to use primary-secondary piping or not. Thanks Ed0 -
As Dan C says,
a tankless water heater is just that, for DHW production.
Try pushing the envelope further(others have), and watch the problems pile-up.
Dave0 -
As Dan C says,
I have pics of some good looking messes!
Dave0 -
Call them
Rinnai commercial models are approved for heat and hot water
use, at least they were. I don't like the option much but did one on small artist studio on an estate once, used brazed plate heat exchanger for radiant side and it worked out just fine. To me this is about the most I would use it for in duo use.0 -
Navien America
Has their "Heating Box" that is designed around using an on demand as the heat source. I installed two systems like this two years ago and they have been working fine.
Small hydronic loads (<2,000 sq ft) can be met this way in a cost effective way.0 -
Found it !
Click resources go to "Hot Tech Topics" and then "7" you will find pictures under "Instantaneous water heaters as heat sources. Feel free to contact me if you have any questions.
Rich K0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
