Looking for pictures of Mod/con boilers opened for service
combustion analyzer
Curious to know which ca you use. Have had lots of service issues with my bacharach.
Thanks0 -
I recently had a no heat on a Vitodens 200 i installed 2 years ago. Had to replace the radial fan (strange). Anyhow i observed the same "crumbs" on the bottom. Is this the "mouse poop" you guys refer to? Also alot of brown staining on the target wall but i think that is staining from condensation because it is a "wet" condensing wall. I have installed a dozen Vitodens 100s in the past year and have yet to be back.0 -
My Bachrach (PCA2) displays the wrong year but otherwise OK. No field adjustment but it goes back in for calibration this spring anyway.0 -
OOPS
My mistake! We don't install the coax venting arrangement because of freeze ups of the grilss and combustion air inlets. We have redone a number of installations installed by others that had the coax venting arrangements. In our area, Montreal, we have some of the highest humidity cold weather in NA. Things that work in Alaska and Minnesota, don't work here. As an example, Bradford/White Eforce condensing hot water tanks get drowned flue passages. We are the only area where this happens.0 -
condensation
I know where your coming from, I'm originnally from Timmins, way north! Often we do things one pipe because of freezing, I here Montreal is a hard place for venting. As for the brown crud, is there a drier vent on the same wall? Kind of looks like a mix of lint and drier sheets. I have a 100 that gets that often, drier vent is 12+ feet away but seems to travel past the boiler vent, unbelievably I moved the drier vent and it has been fine.0 -
Bacharach 300, old, heavy,probably has vacuum tubes in it! works wonderful but doesnt like being cold. Has nox also, kind of interesting to see. Buying a Systronic from KWelectronics, nice machines.0 -
beautiful
beautiful install, like the finger duct for the wiring! How do you like the press fit fittings?0 -
High humidity in Montreal.
That is interesting. Keeps the manufacturers on their toes!0 -
My Testo 327 has been great.0 -
It has been more than 5 years now........
..... and thousands of fittings later, and I don't think I would ever switch back to soldering. Still have to solder a few things, but more than 90% is press. I have only used Viega and since I haven't had any issues, I don't think I would use anything else as long as Viega is available in my area.0 -
Cleaning boiler
Ken, I looked at this German website. Do you know of any USA based distributors of this or a similar product??0 -
excessive cycling?
i wonder if many of these problems are due to excessive cycling?
Ken, does that German maker of the boiler cleaning equipment have an American distributor??0 -
Miniature trees...
Sean from our company found this one.
By the way, effective in four minutes, I'm no longer an employee of this company.
Thanks for the 10 year run guys. It's been great!
ME0 -
cleaner
Buzz
I found that on the NTI website at: http://www.nythermal.com/
Maybe you can source it from them.
Ken0 -
recent heatxchanger replacement
here is a Quietside QVM-9 after 5 years with no service....0 -
ultra
eeeww I didn't know they had quietside boilers installed on the Titanic!
Here are some pics from a 5 yr old Ultra I came across. Not sure how a guy is suppose to get back in to clean the pins toward the back of the hx??0 -
CO
people are fools that do not get condensing equipment like this serviced
rarely do they wake up to complain
guess you could call it natural selection0 -
Installation and Maintenance
The Ultra looks quite good to me, dry, brush-able clinkers if you will. I see no deterioration of the heat transfer surface and the boiler is still working.
They make brushes to clean between the fins. This looks like a nice clean burn and great for 5 years of neglect.
After I do a combustion analysis I look for the start-up sheet in the manufacturer's installation manual. Seven brands and I have not found one filled out in the last 4 years!
I don't think anyone really expects something for nothing, but they sound like it once in awhile.
ultra firebox insulation
does the boiler manufacture sell the brushes to clean or where can I find them?
Also here is a picture of the insulation on the backside of the cover. Is that normal? I had to get the boiler back operating but figured on bidding replacing it next time it needs cleaned.0 -
ModCon boiler service
I find the brushes at my local hardware. Sometimes called radiator brushes.
http://www.drillspot.com/products/439238/Tough_Guy_1VAK6_Radiator_Brush
This picture shows evidence of too much heat (perhaps over-fired. I would clock the meter, the gas pressure and the delta T across the boiler. I would end by filling out the installation startup sheet.
The factory would be a good place to go for more feedback.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
