recommendation for pex crimp system
jd_12
jd_12 Member Posts: 5
mr pex / safelink
http://www.mrpexsystems.com/pextubing.asp
dumb question, but does brand of pex really matter (not talking about alumn pex or onix)?
thanks
  • jd_12
    Hello:
    HO here. I would like to add isolation ball valves for each pex loop (6 loops per manifold, 2 manifolds). Planning on using the inline ball values that crimp the pex line on each end. Can anyone recommend an affordable crimp system? Is one type better than the other (stainless, copper rings)?
  • What Brand?
    What brand PEX do you have?
  • Andrew Hagen_4
    Andrew Hagen_4 Member Posts: 44
    Copper crimp rings
    If it was PAP, the brand would matter. Since it is regular pex, I would recommend copper crimp rings. The tools are reasonable and the rings can be removed and the fittings salvaged.
  • jd_12
    many thanks!
