recommendation for pex crimp system
jd_12
Member Posts: 5
mr pex / safelink
http://www.mrpexsystems.com/pextubing.asp
dumb question, but does brand of pex really matter (not talking about alumn pex or onix)?
thanks
thanks
Hello:
HO here. I would like to add isolation ball valves for each pex loop (6 loops per manifold, 2 manifolds). Planning on using the inline ball values that crimp the pex line on each end. Can anyone recommend an affordable crimp system? Is one type better than the other (stainless, copper rings)?0 -
What Brand?
What brand PEX do you have?0 -
Copper crimp rings
If it was PAP, the brand would matter. Since it is regular pex, I would recommend copper crimp rings. The tools are reasonable and the rings can be removed and the fittings salvaged.0 -
many thanks!0
