Replacing Fenwal hot surface ignition module with Honeywell.
Jim_64
Member Posts: 253
there both made by tx instruments, and checking the spec sheets will tell you the diff if any. but, for your comfort, remichel.com still lists the fenwals as available so.......
Do you see any problem with this?
I've got this Fenwal module on an H.B. Smith boiler and can't find the exact replacement.
Do you see any problem replacing it with this Honeywell univeral HSI module?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
I don't think the Honeywell has the right specs. It has a
cross reference chart in the Honeywell box. Do not use it if the fenwall is not listed in the cross ref chart. Tim0
- 167 Indoor-Air Quality
