Replacing Fenwal hot surface ignition module with Honeywell.
Jim_64
Jim_64 Member Posts: 253
there both made by tx instruments, and checking the spec sheets will tell you the diff if any. but, for your comfort, remichel.com still lists the fenwals as available so.......
