Oil Burner
Matt_17
Member Posts: 5
sw, yes it is a QB burner. It was cleaned, new nozzle and filter at the end of the season last year.
Oil Burner
I have a Weil McLain Boiler/Burner that is 10 years old or so. The burner starts and runs fine, but when it shuts down there is a rumbling sound for a couple of seconds then it stops. It doesn't do it everytime. Any ideals what could be causing this.0 -
oil burner
needs a cleaning call your oil company if its a weil clain burner think about replacing the burner0 -
Possible after drip from bad cutoff.
As suggested, it would need to be tested by a qualified service personel.
Is it a QB burner?0 -
I agree...
You have a package boiler. The Weil Mc is a tight boiler to start with and I never loved there burner. A good burner with a higher static pressure would be a recommended up grade.
The noise you hear is a after burn. Caused either by a poor pump cut off , carbonized end cone , air in the fuel flow. Needs to be looked at.There was an error rendering this rich post.
Time to change a few Things
It is probably time to change the nozzle and oil filter. If you have the original literature install the correct nozzle and clean the nozzle holder. If you do not have the literature call up Weil Mclain and ask what nozzle is to be used. Ask for complete nozzle specifications to include manufacturer of the nozzle. Also ask for the combustion settings as they should be verified and set.0 -
While the QB isn't anyones favorite burner, it sounds like your ready for an annual service.
If I understand correctly it's been about 1 year, be sure you tell whom ever comes out, what's been happening.0 -
Which W-M is it
the Gold or the 68?
- 167 Indoor-Air Quality
