Looking for Yonkers, NY heating contractor
Mad Dog_2
Mad Dog_2 Member Posts: 8,414
That is your best bet. mad dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=299&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Andrew Rudin
    Andrew Rudin Member Posts: 29
    A church in Yonkers needs to replace a pneumatic temperature control system with electric, replace a vacuum condensate return system with a boiler feed system, and install a dual fuel burner. If your firm is qualified and interested, please email me.
  • Andrew Rudin
    My email is andrewrudin@earthlink.net
  • I can't bid on this job, but...
    There is no need to replace the pneumatic control system. Parts ARE still available, as are valve actuators, thermostats and anything else. You probably only need a new compressor,some rebuild kits and if the lines aren't full of oil & water you can operate it for the next 50 years without any problems. Parts are available from any commercial Honeywell distributor. Try the "Find A Contractor" feature on this site.
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    hmm sounds like a church off of Ludlow by riverdale
