Need heating pro that works with 4\" pipe
I need a steam pro to repipe a boiler with 3-inch and 4-inch pipe. Most of the contractors that I have called do not have the equipment to do this kind of work.
This is not a boiler install. It is repiping the present boiler correctly and eliminating all the victaulic fittings and the leaking valve on a main.
We are in Newton, MA. Work would be after the heating season.
Any suggestions?
Steve
Steve from Denver, CO
