Need heating pro that works with 4\" pipe
Steve Garson_2
Member Posts: 712
I need a steam pro to repipe a boiler with 3-inch and 4-inch pipe. Most of the contractors that I have called do not have the equipment to do this kind of work.
This is not a boiler install. It is repiping the present boiler correctly and eliminating all the victaulic fittings and the leaking valve on a main.
We are in Newton, MA. Work would be after the heating season.
Any suggestions?
Steve
Any suggestions?
Steve
Steve from Denver, CO
Are you sure you do not want a new boiler while you are at it? Did you chack the profinder section? Norm Harvey do you work on 3 and 4 inch? I would but the 120 mile commute would take some scheduling to figure out. Are youi going to go threaded or welded?Cost is what you spend , value is what you get.
cell # 413-841-6726
My logic is as follows: The boiler is a recent model and there is nothing more efficient. Piped properly, it will be a cinch to replace the boiler in the future, when the time comes.
I used "find a pro" and had no luck.
How do I reach Norm Harvey?
SteveSteve from Denver, CO0 -
we work with it all the time
Drop me an email and we can discuss this one. I work in Newton almost everyday. Do you have anything against welding the pipe or is treading a must?
When you say you had no luck with find a pro does that mean that prices were too high?
I am fine with welding to the mains, but the header and the risers to the boiler should be threaded.
I work a mile away, so I am pretty flexible on arranging a look.
http://forums.invision.net/Message.cfm?CFApp=2&Message_ID=429090&IsPrint=yes Here is how to find Norm.Cost is what you spend , value is what you get.
cell # 413-841-6726
I hope not as I doubt I would higher a cheap installer for 3" and 4" I think that was what he has is cheap, now sounds he wants a proper job done.Cost is what you spend , value is what you get.
cell # 413-841-6726
Any good prefab shop
or industrial boiler or fire sprinkler supplier, cut pipe to sketch. that is whom we use when we get a big boy. Mad dog
Thanks Charlie!
I'll get in touch with Steve and see if I cant take a "looksie"
If it goes well let me know if you need a helper, I get down to rockland every other friday to pick up my boys from the dark side of the force.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
